Can cleaned. Regen results |
04-22-2017, (Subject: Can cleaned. Regen results ) Post: #1 | |||
Can cleaned. Regen results I was under my truck greasing and looking stuff over today. I was looking at the dpf and realized whoever had it apart last did not put the clamp on right. It was not sealing at the top to doc. So I proceeded to tear it apart to fix it and have a look see inside. I blew it out with air and got some soot out of it. Did a maintenance reset then a forced regen. I did a forced last weekend with very similar results. But it still regens every 2-5 hrs. | |||
04-22-2017, (Subject: Can cleaned. Regen results ) Post: #2 | |||
RE: Can cleaned. Regen results More than likely time to get rid of the mandate... Mine looked better than that when my DPF cracked, $7000 to replace. I got rid of the mandate and have not looked back. | |||
04-22-2017, (Subject: Can cleaned. Regen results ) Post: #3 | |||
RE: Can cleaned. Regen results | |||
04-22-2017, (Subject: Can cleaned. Regen results ) Post: #4 | |||
RE: Can cleaned. Regen results (04-22-2017 )Waterloo Wrote: More than likely time to get rid of the mandate... Mine looked better than that when my DPF cracked, $7000 to replace. I got rid of the mandate and have not looked back. Yes sir I believe you are right. I will probably have to get one done remotely. Fertilizer season so staying close to Oklahoma. Ordered my pyrometer the other day. I'm getting ready. | |||
04-22-2017, (Subject: Can cleaned. Regen results ) Post: #5 | |||
RE: Can cleaned. Regen results Yep, quite a few DPF just cleaned stories on here, and I am not buying this cleaning nonsense. Replace the DPF/DOC or get rid of the mandate. I have the CM-871 too, and when I cracked it all apart to do the EGR Tuneup, and rid myself of the mandate in my driveway... I was like WTF? How the hell did this truck even get down the road? Rocky, you can do the mandate removal yourself, I did mine in my driveway. It was scary at first, but was in all reality a piece of cake. You already have the reader, just pm unilever for the CPL file for your truck. Shoot me your email via a pm and I will send you a gift... ;-) | |||
