| How to best clean the ISX? |
| 05-04-2017, (Subject: How to best clean the ISX? ) Post: #1 | |||
| How to best clean the ISX? First off I would like to thank Rawze for all the great help he has provided me in getting to know the ISX, the good bad and ugly. If it wasn't for Rawze I probably wouldn't have bought a truck with the color red underneath the hood. THANKS AGAIN. Ok So my question was how to best clean the the 871?? Powerwash or engine Degreaser? A wealth of information on this forum, thanks to all for the posts and help. User's Signature: VOLVO VNL 780 Cummins 450HP CM871 W/13 Spd | |||
| 05-05-2017, (Subject: How to best clean the ISX? ) Post: #2 | |||
| RE: How to best clean the ISX? I never powerwash my engine. I spray it down with degreaser like 409 and rinse it off only. Power wash only serves to make electrical connections go nuts. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 05-05-2017, (Subject: How to best clean the ISX? ) Post: #3 | |||
| RE: How to best clean the ISX? Like Rawze stated, 409 or simple green with a spray bottle and a garden hose. I like to use the power washer, not running, but use the wand to rinse with normal water pressure from the spigot. | |||
| 05-05-2017, (Subject: How to best clean the ISX? ) Post: #4 | |||
| RE: How to best clean the ISX? I will give that a try thanks! User's Signature: VOLVO VNL 780 Cummins 450HP CM871 W/13 Spd | |||
| 05-08-2017, (Subject: How to best clean the ISX? ) Post: #5 | |||
| RE: How to best clean the ISX? Spray 9 melts grease and oil instantly. I use a pressure washer, no closer than 2 feet. Never let a truck wash do the engine, asking for problems. User's Signature: 2010 386 Pete CM871, 13 spd. 3.55 | |||
| 05-09-2017, (Subject: How to best clean the ISX? ) Post: #6 | |||
| RE: How to best clean the ISX? I agree with the guys above. Never powerwash mine, simple green and garden hose, then dry off everything I can get to with a micro fiber. If something is really greasey I use a rag and WD40 first, then hit it with simple green to get rid of the WD residue, waterhose and dry. User's Signature: Anti-seize EVERYTHING, Except injectors...Use Petroleum Jelly!!! | |||
