Waterless Coolant systems...Good or Bad? |
02-25-2020, (Subject: Waterless Coolant systems...Good or Bad? ) Post: #10 | |||
RE: Waterless Coolant systems...Good or Bad? (02-25-2020 )E_83 Wrote: Rawze, Those are interesting ideas towards using a bit less water vs. the coolant ratio. Not mixing it 50/50 though would present some inefficiencies with heat transfer. How much loss in heat transfer vs. the goals for reduced boiling / liner damage over time possibilities is unknown. -- I still use a zero pressure system with the copper tubing to catch the overflow. I use the standard 50/50 (premixed) the red/water mix avail at all truck-stops. I just pour it in. My truck now has roughly 390,000 miles on the new liners with it set up this way. So far it works just fine for me. What it is doing to the liners is unknown at this time, so that is why it is still an open ended subject, and why I would not yet just blindly recommend it to others unless they understood that long term, it still might cause harm. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
02-25-2020, (Subject: Waterless Coolant systems...Good or Bad? ) Post: #11 | |||
RE: Waterless Coolant systems...Good or Bad? (02-25-2020 )Signature620 Wrote: ... You are aware that this lowers the overall boiling point of the coolant right? and with egr gone, the liners are overall going to generally run a bit hotter. I am not sure what this would help solve? it would be interesting in what change in the boiling point temp would be vs the advantages of lowering the pressure a bit. It is nowhere near the extreme I have taken mine to, but on mine, I get 8+,sometimes 9+ mpg and do not drive it hard at all, even when loaded heavy. just some thoughts on it anyways. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
02-25-2020, (Subject: Waterless Coolant systems...Good or Bad? ) Post: #12 | |||
RE: Waterless Coolant systems...Good or Bad? This is a good animation of what cavitation actually is. It’s not boiling from temperature so much as people think. It’s boiling from vibration. More hp and torque amplifies this. Also watch close and you will see the piston pressing against the wall of the sleeve on the power stroke. Now imagine big torque and low rpm push on the side of that sleeve with a mid stop liner that doesn’t have enough clamping force from the head because Cummins sets liner height at .010 instead of Rawze recommended .014. That extra .04 is a lot of extra clamp force keeping that liner from dancing around on that shim. Once that liner starts dancing around it’s game over. Looses head gasket and doomed for perpetual rebuild every 30k or so until someone actually does the job right. Most shops are like there all at .010 but one is .09. It’s good. Build it. They don’t realize that .09 isn’t flat anymore and it won’t hold. It’s frustrating to watch people do this. Maybe this animation will help other situations on a different topic. https://youtu.be/5_7PtvziB-Q Proper coolant and radiator pressure fight against the bubbles forming and if they do the coolant additives protect the metal from the bubbles bursting and blasting the liner. So I would think that running a weaker coolant with no pressure would be like diluting our oil with mineral oil then running a lower oil pressure. Not a good idea | |||
