| 1999 sterling l75 |
| 07-20-2017, (Subject: 1999 sterling l75 ) Post: #1 | |||
| 1999 sterling l75 Hello I own a 1999 sterling l75 dump truck It is loosing 1 quart of oil back into the fuel. I was told it was a crack head, but it does not make any sense me because a cracked head usually mixes oil and water, It is a cat 3126 Has any one had any problems like this. I believe it is the injectors any one????? | |||
| 07-21-2017, (Subject: 1999 sterling l75 ) Post: #2 | |||
RE: 1999 sterling l75 (07-20-2017 )leonardarthur Wrote: Hello I own a 1999 sterling l75 dump truck It is loosing 1 quart of oil back into the fuel. I was told it was a crack head, but it does not make any sense me because a cracked head usually mixes oil and water, It is a cat 3126 Has any one had any problems like this. I believe it is the injectors any one????? injector o rings for the high pressure oil system. start there. | |||
| 07-21-2017, (Subject: 1999 sterling l75 ) Post: #3 | |||
RE: 1999 sterling l75 (07-21-2017 )Unilevers Wrote:(07-20-2017 )leonardarthur Wrote: Hello I own a 1999 sterling l75 dump truck It is loosing 1 quart of oil back into the fuel. I was told it was a crack head, but it does not make any sense me because a cracked head usually mixes oil and water, It is a cat 3126 Has any one had any problems like this. I believe it is the injectors any one????? I did even had the injectors tested and changed o rings I was wondering about putting new injectors | |||
