Ultracapacitors, Are they worth it?,... |
05-30-2016, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #10 | |||
RE: Ultracapacitors, Are they worth it?,... We have always run AGM batteries. I change them every 2 years like clockwork while they are still good and use the batteries for other projects (like backup power to this website). User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
05-30-2016, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #11 | |||
RE: Ultracapacitors, Are they worth it?,... (05-29-2016 )biscuits and gravy Wrote: Thanks for starting this thread about the Uktra capacitors and also highlighting the AGMs. Shop around, they go on sale now and then. I have the Fleetrite made by East Penn, group 31, caught them on sale at the International dealer. They should be having that sale again, International tends to keep a regular cycle on their specials. I think the AGMs will be on sale in the next month or two along with the AC compressors. | |||
11-23-2016, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #12 | |||
RE: Ultracapacitors, Are they worth it?,... AGMS are?? Would deep cylce marine batteries, or blue top optima would be good for hotel loads? | |||
08-22-2017, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #13 | |||
RE: Ultracapacitors, Are they worth it?,... If you're the kind of driver who thinks trucks can go thru 2 feet of water, lookout. That explosion Rawze was referring to will happen. Think about the height of the batteries in a Peterbilt...or a Volvo. | |||
08-22-2017, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #14 | |||
RE: Ultracapacitors, Are they worth it?,... (08-22-2017 )bossboy2 Wrote: If you're the kind of driver who thinks trucks can go thru 2 feet of water, lookout. That explosion Rawze was referring to will happen. Think about the height of the batteries in a Peterbilt...or a Volvo. Blow the cab off of the frame... I have enough issues with this truck, explosions are not in the narrative. I'll stick with my AGMs. | |||
08-22-2017, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #15 | |||
RE: Ultracapacitors, Are they worth it?,... Speaking of the AGM's, do you need anything special to use them? I.E, a new/upgraded alternator? Anything like that? | |||
08-22-2017, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #16 | |||
RE: Ultracapacitors, Are they worth it?,... (08-22-2017 )bossboy2 Wrote: Speaking of the AGM's, do you need anything special to use them? I.E, a new/upgraded alternator? Anything like that? Nope, I have all OEM original on board, alternator, cabling (I did replace 100 feet of it with good welding cable due to shitty factory cabling). But, I do have a 3400 watt stereo system that I installed what, two years ago? I put a small AGM in my cab, in the closet. I have the three amps hooked to it, with an ignition controlled selonoid between it and the 4 main truck batteries. That little AGM carries the load and is charged via the alternator when the key is on. No issues with any of the batteries. And I know for a fact, that little AGM has started this truck. ;-) | |||
06-22-2018, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #17 | |||
RE: Ultracapacitors, Are they worth it?,... Does no one carried AGM?? | |||
06-22-2018, (Subject: Ultracapacitors, Are they worth it?,... ) Post: #18 | |||
RE: Ultracapacitors, Are they worth it?,... (06-22-2018 )74bassman Wrote: Does no one carried AGM?? I got mine at MHC in mcdunough,... they work great for us. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
