Cruise control
08-04-2017, (Subject: Cruise control )
Cruise control
Good morning, a friend of mine has a cm871 his cruise works while he idles but don't work while driving...Familiar to anyone? Thanks
RE: Cruise control
What kind of truck? Any codes, lights etc?
 Thanks given by: Coco620
RE: Cruise control
I guess he's had actuator codes & stuff , young kid bought it lije that a year ago & was asking if I ever experienced it it's a W9
RE: Cruise control
Check the settings in the ECM, they may not have it set up right/turned on.
Mine was not set when i put in a reman motor,but that my bad as the guys who put it in didn't know that as they work on Detroit motors and didn't know much about the red motor.. So i had to get it set up....but i need to get it really set up here soon by someone here to get it right. :)
RE: Cruise control
Here is one example on how programming can get the cruise control out of whack ...
http://rawze.com/forums/showthread.php?t...7#pid16777
I could also be the clutch switch, brake switch, parking brake switch, CC buttons, tail shaft speed sensor acting up, or several other things. if the switches are acting up it can do it, or if the programming is not correct it can too.
RE: Cruise control
(08-04-2017 )Rawze Wrote:  Here is one example on how programming can get the cruise control out of whack ...
Thank you Rawze I will let him know & will post the outcome
