| here's my oil sample |
| 08-15-2017, (Subject: here's my oil sample ) Post: #1 | |||
| here's my oil sample well how does it look? it's a cm870 with a little over 20,000 hours on it. Mandate was removed about 1,000 hours ago and has had about 6 oil changes since. log truck oil sample 1.PDF (Size: 674.3 KB / Downloads: 488) | |||
| 08-18-2017, (Subject: here's my oil sample ) Post: #2 | |||
| RE: here's my oil sample Since nobody has responded I guess that means everything looks normal | |||
| 08-18-2017, (Subject: here's my oil sample ) Post: #3 | |||
| RE: here's my oil sample At a glance, I did not see anything that stood out. There is a whole lot more to ensuring someones de-mandate is safe for the engine than just oil sampling. What does your boost get up to max if you push it during a long hill climb? -- Oil temps in a long pull? -- EGT's (or manifold temps)? What color is your oil generally? -- How long does it take to turn dark? Any black smoke when you get on it in low rpm regions? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
