Cm2250 egr tune up sensor part numbers?
03-16-2016, (Subject: Cm2250 egr tune up sensor part numbers? )
Does anyone know the part numbers for cm2250 imap, delta p and exhaust back pressure sensor?
RE: Cm2250 egr tune up sensor part numbers?
(03-16-2016 )jimeneztrans84 Wrote:  Does anyone know the part numbers for cm2250 imap, delta p and exhaust back pressure sensor?
here is the imap and exh. pressure sensor part numbers.
http://rawze.com/forums/showthread.php?t...87#pid1087
Thanks rawze!! Now if anyone has delta p part number?
03-17-2016, (Subject: Cm2250 egr tune up sensor part numbers? )
Delta p part# 4307166 {corrected by Rawze}
$130.06 from cummins
Nice! Thanks
03-20-2016, (Subject: Cm2250 egr tune up sensor part numbers? )
Typo in the part number for delta p sensor, 4307166 is the correct part number
03-21-2016, (Subject: Cm2250 egr tune up sensor part numbers? )
(03-20-2016 )jrdan191 Wrote:  Typo in the part number for delta p sensor, 4307166 is the correct part number
That is correct. I looked it up too. -- i made a correction to the post above for others that might stumble across this thread.
06-05-2016, (Subject: Cm2250 egr tune up sensor part numbers? )
How about the doser for a 2250?
(06-05-2016 )heallen Wrote:  How about the doser for a 2250?
If you are talking about the doser for the DPF, it is kit part #2881761NX. (Replace every 200,000-250,000)
If you are talking about the DEF doser, it is kit part #2888173NX. (Not sure about replacement mileage. Maybe someone else knows.)
Looked them up using Cummins Quickserve.
