Upgrading trans heat exchanger to an oil cooler
09-25-2017, (Subject: Upgrading trans heat exchanger to an oil cooler )
It's about that time. Gotta fix 3 different things on my list at once. When it rains it pours, eh?
My stock heat exchanger is just that. Stock. And at 700k I know I'm running on borrowed time so I need to get it removed before it causes a serious fuckup.
I want to make sure I understand this right. The kit that Eaton sells comes with what is basically an external oil pump that is used to circulate that fluid through the pump...out to a regular oil cooler.
As an option, I can upgrade further by adding an oil filter boss to the case inline with the pump.
By doing this I can essentially remove the heat exchanger all together so there's no more risk of coolant in my transmission. From what I understand this also increases the torque rating of the transmission, how I do not know.
Correct me if I'm jacked up.
I'm considering buying the pump and filter housing alone and using a heavier duty and more durable cooler and stainless fittings with better quality hose. I figure with the stuff I already have that I can probably get it done cheaper as well. While I'm at it I'm going to put in a new shift tower....the old one is a little sloppy, the bushing kit didn't fix all of it.
Transmission is an RTO-16909 upgraded to 16913.
Overhauled @ 927k
RE: Upgrading trans heat exchanger to an oil cooler
When I did mine I used a S-1404 filter kit and it uses a Eaton 17237 filter. And I used a K-1956 cooler kit. Just disconected the oil cooker and a few new hoses now I never see over 170 degrees.
 Thanks given by: Mrkentee
Mines a oil to air cooler. I see 200+ if it's over 80 degrees and I'm pulling a hill. My friend has an oil to water cooler and never goes over 180. But given my option I would prefer a little hotter oil to burn out the water and not have to worry about coolant contamination.
 Thanks given by: Rawze , hhow55 , gatow900
09-26-2017, (Subject: Upgrading trans heat exchanger to an oil cooler )
https://www.ebay.com/p/K-3623-Eaton-FULL.../714933820
Is this a viable option?
(09-26-2017 )hhow55 Wrote:  https://www.ebay.com/p/K-3623-Eaton-FULL.../714933820
thats exactly what is wrong with them. Air cooled is more reliable.
 Thanks given by: hhow55
Exactly. I'll be changing out mine as soon as I verify the correct part numbers with Eaton.
180-200 is the temp range I'm looking for. Oil is hot enough to do the job and cool enough to last awhile.
Overhauled @ 927k
(09-26-2017 )dhirocz Wrote:  Exactly. I'll be changing out mine as soon as I verify the correct part numbers with Eaton.
I have same trans. Just bought k-1956 kit to convert to air cooler. Yes, torque rating increases with air cooler. Better cooling, I guess.
I expect lower temps, and no worry about contamination.
I'm using those coolant lines for a Webasto coolant heater for cold mornings.
 Thanks given by: Brock
(09-26-2017 )Mrkentee Wrote:  I have same trans. Just bought k-1956 kit to convert to air cooler. Yes, torque rating increases with air cooler. Better cooling, I guess.
I find the tourque rating increase interesting, because when I was spec'ing out trucks I was told any engine over a 1650 Tq rating had to be liquid cooled. Maybe that was just a Paccar thing, cause both KW & Pete said the same thing...that was back in '08.
That is one thing about corn binders , as far as I know they all run aircoolers . Believe me though there is a lot of things on a 9900 I would like to grab the engineer by the balls on . Lol
But I am a anal ocd prick on a lot of stuff too.
