CM2250 gear lube reccomendation
11-22-2018, (Subject: CM2250 gear lube reccomendation )
RE: CM2250 gear lube reccomendation
(10-06-2017 )Rawze Wrote:  If you want to be anal about it,.. the sta-lube GL-4,.. if not,.. the super-tech. Myself, i buy the sta-lube by the case when it is on sale somewhere, but the super-tech when not,
I was in a Walmart were the super-tech they had was only GL5. Is that ok for a demandated 2350 ?
User's Signature: I Need to start asking my stupid questions
11-23-2018, (Subject: CM2250 gear lube reccomendation )
I use the sta-lube GL-4 most of the time. The walmart (super-tech) 80-90 GL-5 is what I alternatively use.
 Thanks given by: rrod , DSTdriver
(10-06-2017 )JMBT Wrote:  Ok, I just finished re-reading Rawze's thread about gear lube. I demandated a few months back and have changed the oil 3 times in the last 30K to try and clean out all the soot from 600,000 miles of EPA ignorance. Now the oil is clean as a whistle and I will go back to 15-18K intervals. Now that the engine is cleaner inside I am ready to start adding some gear lube for the added benefits Rawze has spoke of.
Should I run a GL-4 or GL-5 since I am demandated? What viscosity 85W90? Also, do you guys running gear lube adjust the type or amount in winter vs. summer? Is there anyone out there running a Deman CM2250 that can tell me what they have found works well?
Thanks!
I just poured some 85w 140 supertech from walmart in mine today. Pretty thick stuff.
far as I know the gear lube is also good to help protect the camshaft as they can get eaten away if no overhead valve adjustment hasn't been done properly as well
