Lower end
03-22-2016, (Subject: Lower end )
Lower end
Does anyone know of any youtube vids on replacing rods & main bearings? Sequence? One at a time etc? Torques? Thanks
RE: Lower end
You can find everything you need to know, at quickserve.cummins.com
RE: Lower end
Btw, have you found problem on your engine, popping noise?
RE: Lower end
I haven't hhow55, looked at a couple things but everything looks ok, haven't had much work which is perfect time to check these things but weather hasn't cooperated much Saturday is supposed to be nice. Thank you.
RE: Lower end
Do you have a set of timing wedge's, or access to set?.
I would check the base timing
RE: Lower end
I don't, I was looking at that a set on ebay, have the injector leak test tool comming
03-23-2016, (Subject: Lower end )
RE: Lower end
here are some good vids:
https://www.youtube.com/watch?v=0vWeibfi...42m-cXsl-X
RE: Lower end
(03-23-2016 )Sergiu Wrote:  here are some good vids:
Great share! Especially for Detroit guys. At video time 9:35 he shows how to use a sled gauge to check liner protusion.
RE: Lower end
Thank you Sergiu! Sorry hadn't looked at this all day
