|     3482 code and sometimes a 3480    |
|    11-13-2017, (Subject: 3482 code and sometimes a 3480 )   Post: #1   |  |||
|  3482 code and sometimes a 3480    Hey guys long time reader first time poster, I've had this 400hp isx 15 cm2250 for couple months now managed to cha he my thermostat and egr cooler lower pipe, but this regen issue makes me wanna scream lol. She runs fine but throws a code 3482 every once in a while for the last couple days. Regen seems fine runs about 30 min at 900 rpm, I did clean my egr valve after this code and it still pops up now and then, is this something I can tackle myself? And if so any direction to start looking first?   Thanks again Ironhead  |  |||
|    12-13-2017, (Subject: 3482 code and sometimes a 3480 )   Post: #2   |  |||
|  RE: 3482 code and sometimes a 3480    Looks like your question got lost in the noise of things...  did you get this solved? Going through and doing some tune-up work to those systems works wonders on them. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    12-13-2017, (Subject: 3482 code and sometimes a 3480 )   Post: #3   |  |||
|  RE: 3482 code and sometimes a 3480    Sort of, I think it's a wiring issue. I replaced the fuel actuator on the drivers side, it will regen fine, kinda long 45 min or so, rolling tho it'll pop those codes not as much any more. However when they do pop up my fuel mileage goes up slightly but I have to regen after clearing the codes. Next step in gunna take the dpf off and inspect and clean it     |  |||
