broke a Exhaust bolt
12-25-2017, (Subject: broke a Exhaust bolt )
RE: broke a Exhaust bolt
I drilled about half way thru the bolt should i drill all the way?
The deeper the better.
You can do two things.
A. Weld a nut on the end of the stud and try to turn it out. Did a lot of Cat Exhaust manifolds with snapped studs.
B. This is a harder way but still do able.
Heat up the stud and surface around stud.
Center punch stud, get cheap 1/4 allen socket and pound it into center of stud. Spray stud with wd 40 and screw out
 Thanks given by: Rawze , simon999
12-27-2017, (Subject: broke a Exhaust bolt )
I've done some cat manifold studs by sticking a flat washer over the stud. One that just fits over. Then I find a nut to put on top of this and mig or now I tig weld up the center of the nut to the stud. Let cool completely and put a wrench on this nut and work it back and forth. I've had great success doing this.
12-30-2017, (Subject: broke a Exhaust bolt )
Well i got the bolt out with a tool made for ISX broken bolts. Problem is the back of the hole part is messed up i think? Threads are fine in the front so i ran the tap thru to try and make some threads in the back. Looks like they are there BUT after u start tighting the bolt down it spins lose again. Think i need a Helicoil.
http://www.acmeindustrial.com/insert_comparison.html
Has anyone tried this product?
 Thanks given by: gatow900
12-31-2017, (Subject: broke a Exhaust bolt )
(12-30-2017 )hhow55 Wrote:  http://www.acmeindustrial.com/insert_comparison.html
Genuine Heli-coil is the very best out there. Pricy but worth every red cent.
I used to use them on milling machines back in the day for stripped out decks where guys would clamp, loosen, and re-clamp work pieces a hundred times a day, day after day, year after year, and nothing was tougher than Heli-coil ... nothing. those damn things would last 2-3x longer than the original threads in something, and when you did finally wear out a heli-coil, you pull it out with a pair of needle-nose and install another one right in its place and go again.
 Thanks given by: hhow55 , fargonaz , Dtruck , Chamberpains
