EGR Delete Info -- Educate yourself |
08-28-2022, (Subject: EGR Delete Info -- Educate yourself ) Post: #190 | |||
RE: EGR Delete Info -- Educate yourself (08-27-2022 )scott441974 Wrote:(01-05-2017 )Cuya Wrote: There is no place in fl that is worth 2 cents towards that kind of stuff. http://rawze.com/forums/showthread.php?t...5#pid69605 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
02-05-2023, (Subject: EGR Delete Info -- Educate yourself ) Post: #191 | |||
RE: EGR Delete Info -- Educate yourself 2004 T600 cm870 550hp 10 speed UltraShift Will unplugging the EGR when it is in the closed mode be OK and does it help? | |||
02-05-2023, (Subject: EGR Delete Info -- Educate yourself ) Post: #192 | |||
RE: EGR Delete Info -- Educate yourself Unplugging the EGR temp sensor will put it in protection mode, doesn't hurt it but does cause a derate, atleast it's not eating soot though. I've heard of people driving a LONG LONG time with it unplugged. Your better off to just get it demandated. User's Signature: Warranty??? Yeah right, I am the warranty!!! | |||
02-05-2023, (Subject: EGR Delete Info -- Educate yourself ) Post: #193 | |||
RE: EGR Delete Info -- Educate yourself (02-05-2023 )StepdeckBob419 Wrote: 2004 T600 cm870 550hp 10 speed UltraShift 2004 is a CM870 engine... The egr temps sensor is the thing to unplug.. not the egr valve.. for the CM870's, it will not hurt it to just derive it with it unplugged. ppl drive them a million miles like that .. CEL light will be on and it will have a slight boost derate, turbo will run hotter than normal (depends on how hard its driven), .. so at some point, a properly made de-mandate program will be the better option though. Forum member 'running rough' does most of the CM870's for people around here. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
