|     Need help..cm2250    |
|    02-08-2018, (Subject: Need help..cm2250 )   Post: #1   |  |||
|  Need help..cm2250    Code displayed is SPN 3251...looked it up and I believe it’s back pressure issue with the def filter...looking for more layman terms possible problem and solutions please     |  |||
|    02-08-2018, (Subject: Need help..cm2250 )   Post: #2   |  |||
|  RE: Need help..cm2250    User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    02-08-2018, (Subject: Need help..cm2250 )   Post: #3   |  |||
|  RE: Need help..cm2250    Can you point me in the right direction to Mr hag I guess is what his name is or someone close to the Ohio ,West Virginia ,Pennsylvania area that can help fix my problem keep it out of the cummins and Freightliner shop     |  |||
|    02-09-2018, (Subject: Need help..cm2250 )   Post: #4   |  |||
 RE: Need help..cm2250  (02-08-2018 )ChuckkBuckk70 Wrote: Can you point me in the right direction to Mr hag I guess is what his name is or someone close to the Ohio ,West Virginia ,Pennsylvania area that can help fix my problem keep it out of the cummins and Freightliner shop GEAR HEAD is in PA try him here on the forum. We are in GA  |  |||
|    02-12-2018, (Subject: Need help..cm2250 )   Post: #5   |  |||
|  RE: Need help..cm2250    Thank you     |  |||
