Egr tune up
03-31-2016, (Subject: Egr tune up )
Egr tune up
Hello everyone
I am looking to do the complete Egr tune up. Before I start just wanted to make sure I have new sensors on hand incase they are bad. Will be working on 2011 prostar with cummins isx 09 year engine
What sensors do I need to get.
What are part numbers
So far I found by searching on this site
I map Delta p and Egr exhaust pressure sensor
Is there more sensors that need to be changed
RE: Egr tune up
(03-31-2016 )stl530 Wrote:  Hello everyone
It sounds like you have a good list started.
here is more on this...
http://rawze.com/forums/showthread.php?tid=7&pid=9#pid9
04-01-2016, (Subject: Egr tune up )
RE: Egr tune up
Yes thanks I watched all of those videos. changing imap delta p n egr exhaust pressure sensors are common sensors that go bad
RE: Egr tune up
There is one down at the DPF, maybe two, been awhile... When I eliminated the mandate, I found the tubes going into the DPF were stopped up with soot, the sensor(s) the same. Nothing was functioning under there. And if you mess with the metal tubes coming off of the DPF can, be prepared to have them snap off on you, mine did, looked like cheap pot metal and broke under very little force. I could see a well placed road stone taking one out if it hit the sweet spot. Nothing but junk under there, and designed to fail in my book.
RE: Egr tune up
Anyone know all the parts numbers maybe I can find em on ebay
04-03-2016, (Subject: Egr tune up )
RE: Egr tune up
are these the correct part numbers
4928594 pressure sensor
2897334 I map
4307166 delta
for 09 Cummins engine
RE: Egr tune up
The best way to find all your CORRECT part numbers is to go to quickserve.cummins.com, and enter your ESN.
