CM570 Cams
04-01-2018, (Subject: CM570 Cams )
RE: CM570 Cams
Quote:
 Thanks given by: Five Star , fargonaz
RE: CM570 Cams
Liners and counterbores at .12
RE: CM570 Cams
Almost ready to start up
RE: CM570 Cams
(04-01-2018 )Pd6cas2 Wrote:  Almost ready to start up
Looks like a nice job, congrats! Do you live in the RGV or just buy your parts there? I live in Harlingen and have a yard in Donna, Tx and one in Laredo. 2 million miles, wow. Any info on the amsoil program that you mentioned above?
RE: CM570 Cams
Great info and great pics as well! Yeah the shop has all correct tooling for critical parts. Any thought on an actual “break in” oil, or just Rotella 15-40? My next question would be, would a guy start it out on gear lube regiment, or wait a oil change or two?
RE: CM570 Cams
I live 30 miles north St Paul,Mn.
I go to the Valley 11 months out of the year.
Amsoil is not the reason for long engine life,they happen to headquartered right up the Road.
They do my samples and I get results in 48 or less .
Engine was inframed before at 500k,
RE: CM570 Cams
I do have Amsoil Oil bypass system but not for extended oil drains.
RE: CM570 Cams
(04-01-2018 )Pd6cas2 Wrote:  Liners and counterbores at .12
top of that deck looks a little rough for my tastes. Otherwise, lookes good.
 Thanks given by: Pd6cas2 , hhow55 , Signature620
RE: CM570 Cams
Cummins tech says hes working on N14 nonstop.
Guys are buying from salvage yards and when putting together Block deck is too pitted or Counterbores too off...
