Oil pump shim
05-27-2017, (Subject: Oil pump shim )
Post: #46
RE: Oil pump shim
it stops nothing with the fuel pumps exploding. all it does is when the filter plugs off when the pump explodes oil pressure drops long enough before it bypass to shutdown/give you some warning of shits going bad. cummins bandaid on a amputation!
 Thanks given by: Hammerhead , t700 , Rawze , redbeard , scottydogtruck
Post: #47
RE: Oil pump shim
(05-27-2017 )Unilevers Wrote:  it stops nothing with the fuel pumps exploding. all it does is when the filter plugs off when the pump explodes oil pressure drops long enough before it bypass to shutdown/give you some warning of shits going bad. cummins bandaid on a amputation!
:(:(:exclamation::exclamation::exclamation::exclamation::exclamation::anger:
