|  What would cause black oil in a tuned engine  |
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #1 | |||
| What would cause black oil in a tuned engine  I've read numerous times on here that your oil should stay clean (not black) after a proper tune. What would cause you to have black oil after a proper tune?  | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #2 | |||
| RE: What would cause black oil in a tuned engine  An improper tune.  | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #3 | |||
| RE: What would cause black oil in a tuned engine  depends on how much you idle, the shape of the engine and injectors, and a whole lot of factors.  User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #4 | |||
| RE: What would cause black oil in a tuned engine | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #5 | |||
| RE: What would cause black oil in a tuned engine (04-29-2018 )tree98 Wrote:(04-29-2018 )Waterloo Wrote: An improper tune. do some oil sampling and stop guessing. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #6 | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #7 | |||
| RE: What would cause black oil in a tuned engine  When I first tuned my truck, it took several oil changes to wash out the soot that had been living in my motor for hundreds of thousands of miles. About the third change it stayed honey brown for well over 12,000 miles.  | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #8 | |||
| RE: What would cause black oil in a tuned engine  Same here, when I did mine it took me dropping the oilpan for a night to clean it up.  User's Signature: I'm no mechanic, I'm just a guy that breaks down enough to know a bit. | |||
|  04-29-2018, (Subject: What would cause black oil in a tuned engine )  Post: #9 | |||
| RE: What would cause black oil in a tuned engine  Do you have a bypass filter on it? My new long block turns oil black around 10,000 miles with a MommaBurt tune and without a bypass filter. I have to sample this one cause i think it turned black a little fast. But this was also the first time I used gear lube in it. And I'm at 45,000 on it so 1st overhead adjustments are about due.  | |||
