Picking up Cascadia ISX 450
05-27-2018, (Subject: Picking up Cascadia ISX 450 )
Setup Goes As Follows:
2012 Cascadia ISX 450
10 SPEED
Leased out to hood since 2012
Purchase price 24850 from 28850
604K miles
What should I do first? Where should I bring it to make sure its up to par since the stealership isnt a good idea?
I'm here to learn and be successful so please take it easy on me..
RE: Picking up Cascadia ISX 450
I assume if that truck was leased nobody take care just pushed pedal to the floor.
First thing renew fuel pump otherwise you risk to lose your engine. If it still has ceramuc plungers , particles will go through oil galeries and destroy everything. Replace fuel pump plunger &barrels, tappets. You can check my video
https://youtu.be/u0b_0_CCDiM
and follow cummins quickserv. Or you can head up to atlanta mr Hagg shop, they can update it for you.
 Thanks given by: rrod
The plungers were replaced in 2017. Thank you for the advice
