2350 fuel pump
06-09-2018, (Subject: 2350 fuel pump )
Post: #19
RE: 2350 fuel pump
(06-09-2018 )Rounded_nut Wrote:  I just did mine, not bad but that vice better be solid because those plungers are tight! You need a... 12 point? socket, you'll probably want a swivel too. Things the manual left off.... The fuel line holding bracket just above the pump, remove the 2 bolts, the banjo bolt that has the screen in it, replace it since you're there anyways and order 3 of the orings for it because you'll probably lose one, matter of fact make sure you get enough damn oring washers, cheap insurance.
On the 2350 there is an updated roller pin, old was fixed ends made of brass, new is a floating pin with rounded ends, don't tip the lifter because the pin will silently try to escape! When I did mine the cam and everything looked very good, but be sure to look at yours, and don't forget to have fun!
I did on mine 440,000 miles. Everything also looked good
06-13-2018, (Subject: 2350 fuel pump )
Post: #20
RE: 2350 fuel pump
was looking online at the fuel pump barrel and plunger repair kit has any one bought one before the price seam a little low in would that fix the biggest part of it messing up the motor
Post: #21
RE: 2350 fuel pump
I wouldn't use any parts in your pump that aren't GENUINE CUMMINS !!
Post: #22
RE: 2350 fuel pump
(06-13-2018 )tree98 Wrote:  I wouldn't use any parts in your pump that aren't GENUINE CUMMINS !!
i look on goggle just to get a ball park in the pete store was showing a price that seam low..ill call my dealer up in check with them
Post: #23
RE: 2350 fuel pump
but would the repair kit come with the upgrade plunger
06-28-2018, (Subject: 2350 fuel pump )
Post: #24
RE: 2350 fuel pump
ok having problem finding the fuel pump repair ki went on cumming website in punch in my parts number in it keep saying not availble any clue were els to look at for parts
Post: #25
RE: 2350 fuel pump
Check with Mr. Hagg
