Crankshaft Pin Location on 2250
06-23-2018, (Subject: Crankshaft Pin Location on 2250 )
I am checking my Timing gears. I can't seem to find the Crank Pin location on the block, I have the Pin and the Timing tools. It's not the same as my 871. Anyone Know?
My 871 is at the Drain for the Crank Case Ventilation tube.
06-24-2018, (Subject: Crankshaft Pin Location on 2250 )
RE: Crankshaft Pin Location on 2250
It's in the exact same location, it may just be a plug with a 6mm allen key head. It's right under a small cutout in the fuel pump/air compressor support bracket.
