need help (steer tire advice)
06-27-2018, (Subject: need help (steer tire advice) )
just had a steartire blow out n the shop i called only have 275 but i had 295 on it now if i buy 2 275 would that mess up anything or should i keep calling around tell i fine the 295
RE: need help
What size doyo have on the drive's?
I would say, stay with the same size you have on the drive's. The difference between the 275vs 295 is the 275 is smaller in diameter.
Just my 2 cents
RE: need help
i have 295 75 22.5 on my steer now but one just went out on me in it time for new ones but the shop i called for steer tires only have 275 75 22.5not sure what to do
RE: need help
(06-27-2018 )lonestar16 Wrote:  just had a steartire blow out n the shop i called only have 275 but i had 295 on it now if i buy 2 275 would that mess up anything or should i keep calling around tell i fine the 295
What is the aspect ration on old and new tire. 275 is tire width.
RE: need help
The 275 will be a Michelin while the 295 will be a not Michelin. The overall diameter difference is only about 1/10" on two brand new tires.
A few years ago I had a mechanic fail my bi annual inspection because I had 275 and 295 tires on the same axle end. The thing that pissed me off was all the tire manufacturers say that if the tires are within 1/4" diameter they are considered matched good enough to be at the same axle end. My odd tires were within 1/4" circumference but that didn't matter to him, had to buy a couple of tires and move a few others around to make him happy.
RE: need help
(06-27-2018 )kryten Wrote:  The 275 will be a Michelin while the 295 will be a not Michelin. The overall diameter difference is only about 1/10" on two brand new tires.
the steer tires i have now r 295 75 22.5 goodyear but the shop im at only have 275 80 22.5 bf goodwreanch ...would i be o if i replace both steer tire or call around in fine the same size i have on here now..
RE: need help
275-75 is too small. Not really good to drive long time because it affect frame and rear ends position. You can single drive axle and limp to the next available place to fix. Just drive slower.
Where you are sitting?
RE: need help
(06-27-2018 )snailexpress Wrote:  275-75 is too small. Not really good to drive long time because it affect frame and rear ends position. You can single drive axle and limp to the next available place to fix. Just drive slower.
the tires r on my steer axle ....
RE: need help
I understand. But frame height on the rears changes too if frame is not even to the ground level
 Thanks given by: lonestar16
