Massive oil leak...
07-22-2018, (Subject: Massive oil leak... )
Post: #19
RE: Massive oil leak...
I don't really have away on steam cleaning the engine. i don't think this shop does either its a small shop by st louis. but im have them check the filter under pressure make sure the seal isn't leaking or somthing
07-23-2018, (Subject: Massive oil leak... )
Post: #20
Get a case of brake clean then and start hosing off the oil. Degreaser and a garden hose. You need to clean it up some how. Get creative.
Post: #21
Well its caused by Blow by.. White smoke is pouring out the exhaust and blow by and oil fill tube.
 Thanks given by: Nostalgic , snailexpress
Post: #22
Before making the sign of the cross, isolate the turbo, make sure you don't have a blown shaft seal.
 Thanks given by: Chamberpains , Pete1990
Post: #23
(07-23-2018 )Moose Wrote:  Before making the sign of the cross, isolate the turbo, make sure you don't have a blown shaft seal.
That was the first thing the shop did this morning.
Here is the video of the blow by
https://youtu.be/DXZmB8W-cRY
Post: #24
A cracked piston will do that.
Post: #25
Hory shet.....
My most heartfelt apologies.
Post: #26
Hate to confirm. My did absolutely same.
07-24-2018, (Subject: Massive oil leak... )
Post: #27
I'm sorry about that but you have a hole in one of your pistons.
