Barometric ambrient pressure sensor wrong reading |
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #1 | |||
Barometric ambrient pressure sensor wrong reading Hello everyone. I got deleted cm 871. My ecm derates to 30- 33 psi of boost, due to high altitude. So I completed barometric pressure reading (24.5 in Hg) with current barometric pressure (30.1 In Hg). So difference is huge. I put a new sensor and got my 38 psi boost back to normal, But next morning problem reappeared. I bought another sensor, and switched them around with no success. Harness and plug looks nice and clean. Does anybody knows if ecm uses any other sensors to calculate barometric pressure?[/size] | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #2 | |||
RE: Barometric ambrient pressure sensor wrong reading Just that sensor. Check for moisture in connectors and check continuity between the sensor and ECM. | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #3 | |||
RE: Barometric ambrient pressure sensor wrong reading (07-23-2018 )koliunia Wrote: Hello everyone. I got deleted cm 871. My ecm derates to 30- 33 psi of boost, due to high altitude. So I completed barometric pressure reading (24.5 in Hg) with current barometric pressure (30.1 In Hg). So difference is huge. I put a new sensor and got my 38 psi boost back to normal, But next morning problem reappeared. I bought another sensor, and switched them around with no success. Harness and plug looks nice and clean. Does anybody knows if ecm uses any other sensors to calculate barometric pressure?[/size] Also could be the symptoms of a bad delete program too. - Who did it? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #4 | |||
RE: Barometric ambrient pressure sensor wrong reading My delete was done by Ken in Indiana. I did clean connector with electric cleaner. I was driving CA NV UT, and it's extremely dry in here, I doubt any moisture could even get in there. I'm going to test voltage, when I get home. Thank you for your input! | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #5 | |||
RE: Barometric ambrient pressure sensor wrong reading (07-23-2018 )koliunia Wrote: My delete was done by Ken in Indiana I don't trust his work any more. Seen a lot of bad stuff from that shop over this past year. I would have the program checked out to ensure it is ok too. The last thing you need is for it to be running in a high altitude mode at low altitudes. It could cause it to eventually burn a piston or drop a liner. Some engines use the crank case pressure sensor and IMAP to verify the altitude sensor reading. Anyone bothered to replace the IMAP or crank case pressure sensors? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #6 | |||
RE: Barometric ambrient pressure sensor wrong reading How do I check my tune? I tried to reach Ken, but he newer answers call / messages | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #7 | |||
RE: Barometric ambrient pressure sensor wrong reading (07-23-2018 )koliunia Wrote: How do I check my tune? I tried to reach Ken, but he newer answers call / messages If you e-mail the program to me out of the truck, I can look it over. If you are in the Atlanta area and can stop by, I will look it over with you. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #8 | |||
RE: Barometric ambrient pressure sensor wrong reading crankase sensor has been replaced recently, but problem was on my harness and plug itself. I will plug my old sensor to see if it's changes anything. Imap was been replaced a year ago. Will buy and replace one today. What's your email address? | |||
07-23-2018, (Subject: Barometric ambrient pressure sensor wrong reading ) Post: #9 | |||
RE: Barometric ambrient pressure sensor wrong reading I PM'd you my number and email. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
