| Cruise control randomly shutting off |
| 07-26-2018, (Subject: Cruise control randomly shutting off ) Post: #1 | |||
| Cruise control randomly shutting off 09 prostar here. It started 2-3 months ago and it progressively got worse. While cruising it suddenly disengages, the "cruise set" disapears from the screen, like when you press off, and it won't engage back if i press on until it randomly decides to re-engage when i press it again. Engine brake works. To me it seems like some connection is overheating and needs to cool down. Now it got to the point where it cruises for anywhere from 5 to 30 min then won't engage for 20 min or 30 or 5. It's random and it bugs me.I can't seem to find any fuse related to cruise control altough i pulled out and cleaned every single fuse. I checked the brake and clutch switches but they seem to work properly. I asked my friend whos a electrical engineer at navistar and he said it might be software related. Anyone had similar issues? Thanks to all and safe travels! | |||
| 07-26-2018, (Subject: Cruise control randomly shutting off ) Post: #2 | |||
| RE: Cruise control randomly shutting off What did you use to check the clutch and brake switch? If it has a Cummins in it, Insite is will allow you to monitor the cruise circuit and all related switches. | |||
| 07-26-2018, (Subject: Cruise control randomly shutting off ) Post: #3 | |||
| RE: Cruise control randomly shutting off read through this post well... http://rawze.com/forums/showthread.php?t...2#pid16882 and this one ... http://rawze.com/forums/showthread.php?t...1#pid12861 Don't just clean the fuses mentioned, replace them. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 07-26-2018, (Subject: Cruise control randomly shutting off ) Post: #4 | |||
RE: Cruise control randomly shutting off (07-26-2018 )Rawze Wrote: read through this post well... I got the red and few other ones replaced a while ago. Also i gotta put silicone in all those nice places on the cab. My friend also said to check the button connection on the steering wheel and if thats all good just replace the button, wich costs more than my car payment from what i saw haha. I'll get to it this weekend hopefuly and i'll let you guys know. Thanks! | |||
| 07-29-2018, (Subject: Cruise control randomly shutting off ) Post: #5 | |||
| RE: Cruise control randomly shutting off Here is an aftermarket pod kit https://www.raneystruckparts.com/interna...611199c91/ Here is an OEM https://www.ebay.com/itm/INTERNATIONAL-2...m570.l1313 And here is a brand new ProStar steering wheel with the pods for $250... Now that is a deal! https://www.ebay.com/itm/STEERING-WHEEL-...m570.l1313 | |||
