After treatment history
09-22-2018, (Subject: After treatment history )
RE: After treatment history
Check out the ECM Time column, yours is trying to regen too often. I looked at an old work order when everything was working correctly on mine it was right there at a hundred hours.
09-23-2018, (Subject: After treatment history )
I'll keep and eye on it just got insite for it a new start on thing to watch
(09-22-2018 )schISM Wrote:  Check out the ECM Time column, yours is trying to regen too often. I looked at an old work order when everything was working correctly on mine it was right there at a hundred hours.
thanks for sharing that. The 2350 seems to not regen nearly as often as my older 871. Its a shame they are just as unreliable.
 Thanks given by: schISM
Cents I change the doser and the nox sensors behind the turbo do I need to reset anything or just leave it alone
Healthy 871s in Australia go between 80-100hrs between burns. There are also several revisions of DPF filters with different flow rates and ash plugging limits.
