|     Used rear end    |
|    09-28-2018, (Subject: Used rear end )   Post: #1   |  |||
|  Used rear end    Where’s the best place to find a used MT-14XM Amboid 355 ratio 40 K rear end. And yes I got more trouble, I’m snake bit.    Thanks in advance  |  |||
|    09-28-2018, (Subject: Used rear end )   Post: #2   |  |||
|  RE: Used rear end    What speeds and loads are you trying to accomplish?  http://rawze.com/forums/showthread.php?t...3#pid17353 User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    09-29-2018, (Subject: Used rear end )   Post: #3   |  |||
 RE: Used rear end  (09-28-2018 )Rawze Wrote: What speeds and loads are you trying to accomplish? Just going back with what it had, mine went out  |  |||
|    09-29-2018, (Subject: Used rear end )   Post: #4   |  |||
 RE: Used rear end  (09-29-2018 )Ronnie4447 Wrote:(09-28-2018 )Rawze Wrote: What speeds and loads are you trying to accomplish? I got mine replaced at weller. was quoted last year, $2400 for the front, $1300 for the rear. I replaced the front because it was going to cost $1900 just in parts to rebuild it myself. I just yanked it out of the housing, took it up there and had the replacement back at the house in an hour sitting in the back of my pick-up. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!.  |  |||
|    09-29-2018, (Subject: Used rear end )   Post: #5   |  |||
|  RE: Used rear end    Probably more depends on your location? I did a quick search of those part numbers and seem to be plenty at around the $1000-1400 price range. If rebuilt is only a few hundred more? grab that sign and stand out on the corner "help, need a bottle of thunderbird"     |  |||
|    09-29-2018, (Subject: Used rear end )   Post: #6   |  |||
 RE: Used rear end  (09-29-2018 )Rawze Wrote:Thanks again I had never heard of Weller, looked them up and and they got places all over. I always let the shop worry about it. When I was running several trucks the shop did a good job taking care of everything that was ten year ago, Can't find anyone I trust or that will do things right and you know from previous post I'm done with dumberships. I'll learn this stuff just got to get the tools and equipment for this new stuff.(09-29-2018 )Ronnie4447 Wrote:(09-28-2018 )Rawze Wrote: What speeds and loads are you trying to accomplish?  |  |||
