Another oil pressure thread
11-19-2018, (Subject: Another oil pressure thread )
Post: #37
RE: Another oil pressure thread
(11-19-2018 )Rawze Wrote:  As a last resort, maybe take it over to Mr. hags shop just s.e. of atlanta?. Maybe get a second set of eyes on it.
That would be a long ways to send it on a hook.
User's Signature: Have you checked your muffler bearings today?
11-21-2018, (Subject: Another oil pressure thread )
Post: #38
Pulled all the rods out of the way this week and it’s worse than the cheap plastigauge set indicated.
With a proper measuring tool two rod journals were over .007 and two were over .008. I believe four rod journals being over .007 under size is sufficient to cause dramatic oil pressure lose.
Time to pull the crank and get it turned.010 under and get appropriate rod bearings.
The shoddy work people do today and pass off as good work astounds me.
Post: #39
(11-21-2018 )Peashooter67 Wrote:  Pulled all the rods out of the way this week and it’s worse than the cheap plastigauge set indicated.
That's why doing your own work saves you so much more than a shop bill. Even good shops will never take as much care as you take with your own equipment. And good shops are few and far between.
12-29-2018, (Subject: Another oil pressure thread )
Post: #40
Here we are to the finally, the conclusion, the end of the road, the final score........
Use what ever euphemism that floats your boat .....
Post: #41
Evidently the computer erased Everything I said.
If what ever I said can be fixed so my post shows up that would be great.
Post: #42
Bottom line
The short and skinny
New rod and main bearings supplied with freshly polished crank by Cummins in Fort Worth
And oil pressure is better than normal.
 Thanks given by: snailexpress , Rawze , Waterloo , Andre_The_Giant
12-30-2018, (Subject: Another oil pressure thread )
Post: #43
(12-29-2018 )Peashooter67 Wrote:  Bottom line
It is nice that you figured it out. Makes someone wonder how it got that bad to begin with.
Post: #44
Wrong rod and main bearings were used in the original rebuild
 Thanks given by: Waterloo , Andre_The_Giant
Post: #45
(12-30-2018 )Peashooter67 Wrote:  Wrong rod and main bearings were used in the original rebuild
WTF..... wrong parts? Same thing that happened to Waterloo. And they charge ridiculous money for these hack jobs.
