Eld picking up codes but no CEL 2011 Prostar ISX
11-14-2018, (Subject: Eld picking up codes but no CEL 2011 Prostar ISX )
Hey guys,
My Rand Mcnally Eld is picking up these codes. I've attached a screenshot. There's no CEL. Truck runs fine. What are your thoughts? 2011 International Prostar Cummins isx.
RE: Eld picking up codes but no CEL 2011 Prostar ISX
All codes not related to the engine so it will be no CEL.
You need to buy adapter and run some test.
For rear suspension pressure sensor you can use ACom Diagnostic from Bendix if truck equipped Bendix system
Wabco i think provide soft for free as well, not sure.
Lights codes you can check with Diamond. Probably bad LCM or wiring.
Thank you for the clarification!
