Fuel Issues |
11-16-2018, (Subject: Fuel Issues ) Post: #1 | |||
Fuel Issues My son had unloaded in Reno Had the truck washed and a PM at Speedco yesterday. Parked the truck at the TA and spent last night. Took off this morning headed to California to book a load got up to 1500 rpms engine started cutting out and threw codes 559 and 2346 which have to do with the exhaust gas temperature. These codes deal with amount of fuel going to the fuel rail. I'am sure many of you can explain these codes better than me. After realising that it had to do with fuel we went back to Speedco. They checked the filter #s and said they were correct and bled any air out of system and stated what they had done was correct. We still had the problem After thinking on it we decided to have Speedco to replace the filters anyway When they removed the 2nd filter the guy said that it was in fact the wrong filter. Installed correct filter and all is well. Reset all codes with Insite Thankful we got it fixed Hopefully this may help someone T700 | |||
11-16-2018, (Subject: Fuel Issues ) Post: #2 | |||
RE: Fuel Issues You didn't happen to get the filter number of the wrong one, did you? This may help even more. Plus we can look in to why the filter fit and didn't work, causing your problems. | |||
11-16-2018, (Subject: Fuel Issues ) Post: #3 | |||
RE: Fuel Issues (11-16-2018 )Chamberpains Wrote: You didn't happen to get the filter number of the wrong one, did you? Did not get the # of the wrong filter. Speedco had looked at filter number on receipt, but when they changed it realised it was incorrect. Could have been packaged wrong? Not sure of the other details,just relieved that the problem was solved. Your right should have got more details. Just posted to help in case this happens to someone else T700 | |||
