Ism injector |
12-03-2018, (Subject: Ism injector ) Post: #1 | |||
Ism injector I have a 2003 ism. No Jake's. How long should it take to change an injector? I've only changed injectors in a isx, I imagine if I can do a isx a ism would be easy? Cummins said it would take less than 4 hrs I want to save money. Thanks | |||
12-08-2018, (Subject: Ism injector ) Post: #2 | |||
RE: Ism injector So I am in the process of changing the injector. I got the new one in but I can't find the timing marks. I'm assuming it's because the pulley is so rusty and pitted. I've tried cleaning with a wire wheel but can't find. So.... My question is since I'm changing the injector on the number 2 cyl can I roll over motor till number 5 cyl valves start to move? Or does it not work like that? I was thinking if number 5 is moving then number 2 is closed. Thanks | |||
12-08-2018, (Subject: Ism injector ) Post: #3 | |||
RE: Ism injector The marks are usually hard to find. They can be on the front or back lip of the fuel pump/accessory drive pulley. If you bar it around until the intake of #5 travels all the way open then stops you'll be very close. At this point, see what you can find close to the 12 oclock position on the pulley. | |||
12-08-2018, (Subject: Ism injector ) Post: #4 | |||
RE: Ism injector I did that but couldn't find the marks still. It's so pitted and rusty but I used that and did my adjustments. Runs good. Thanks for the help | |||
