You need one of these if you do electrical work!
01-21-2019, (Subject: You need one of these if you do electrical work! )
Rawze got me hooked on YouTube videos... I just saw this... Lisle 32150 Power/Ground Outlet https://amzn.to/2POTzQ0 and ordered.
Tell me you guys could not use this? How hard is it to find a ground in these new trucks, almost impossible unless you have a grounded post in your dash, like Rawze. And I have looked for these grounded posts like Rawze does have, and have had no luck. I remember when the truck stops sold them, I look now and then with no lock, and have failed on the internet finding one that will mount in the dash and accept a proper ground wire from behind. So...
I normally hook to the door hinge thingy, and, more than a few times destroy the clip on the 12 volt tester when the wind blows the door shut! Or, I forget about the clip and shut the door!
I am getting tired of repairing that thing. Found a solution. Hope this helps out. ;-)
 Thanks given by: ynot , rrod , flatbed94kid , imalumberjack , Toolguy
RE: You need one of these if you do electrical work!
I like that other tool u showed that I solder and has a lighter on it.
User's Signature: Also known as Shotgun
01-22-2019, (Subject: You need one of these if you do electrical work! )
(01-21-2019 )flatbed94kid Wrote:  I like that other tool u showed that I solder and has a lighter on it.
This baby... The Power Probe! It rocks... https://amzn.to/2Wl4X8H
 Thanks given by: Toolguy
