CM2250 |
02-11-2019, (Subject: CM2250 ) Post: #1 | |||
CM2250 New code after just leaving the shop. First day back on the road. I have a code of SPN 102 FMI 18. I goggled it and it says low boost pressure. Is there something I can try to fix this code. It may be a leak and I do smell fumes. Please help. I just spent 5k to get my truck back on the road | |||
02-11-2019, (Subject: CM2250 ) Post: #2 | |||
RE: CM2250 What did you have the shop do? Also need some engine history like Miles, is it demandated? If so by who? User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
02-11-2019, (Subject: CM2250 ) Post: #3 | |||
RE: CM2250 I had a radiator and delete done. The check engine light is going on and off. Them medium level one for Volvo’s. I have 621k miles. I don’t have lost of power or a detente issue. Could it be the boost sensor or imap sensor. Other than that it seems to be driving fine. | |||
02-11-2019, (Subject: CM2250 ) Post: #4 | |||
RE: CM2250 What is demandated | |||
02-11-2019, (Subject: CM2250 ) Post: #5 | |||
RE: CM2250 Demandate is what you had done. It's very possible they did it wrong. User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
02-11-2019, (Subject: CM2250 ) Post: #6 | |||
RE: CM2250 How can I check if they did it wrong or not? | |||
02-11-2019, (Subject: CM2250 ) Post: #7 | |||
RE: CM2250 YOU can't. You'll have to get someone to look at it that knows what they are doing. Unilever,Mommaburt, gearhead, mr. Hag, Rawze. What state/city are you in right now? User's Signature: im_seeing_parameters_in_my_sleep 1 | |||
02-11-2019, (Subject: CM2250 ) Post: #8 | |||
RE: CM2250 I’m in NJ | |||
02-11-2019, (Subject: CM2250 ) Post: #9 | |||
RE: CM2250 Do I just call and say I’m from Rawze | |||
