Flir
02-22-2016, (Subject: Flir )
Flir
Rawze, your IR camera was very impressive, price was a little high for my budget. I found this little gizmo from FLIR and at $250 very affordable for anyone with a smart phone.
How does it compare as far as resolution?
http://www.flir.com/flirone/content/?id=69420#specs
02-23-2016, (Subject: Flir )
RE: Flir
(02-22-2016 )in2trux Wrote:  Rawze, your IR camera was very impressive, price was a little high for my budget. I found this little gizmo from FLIR and at $250 very affordable for anyone with a smart phone.
The resolution is very very low, so they make up for it with a second camera.
I did a lot of research before I got the therm-app.
Here are some pics from different people's engines that come over here to get their truck straightened out, custom tuned, etc. -- I don't mess around.
./uploads/201602/post_1744_1456213068_529f88e7ac2f0565637d6f2923142ac4.jpg
and some battery problem..
./uploads/201602/post_1744_1456213126_cae22ba2a6ad9527051d35e997f2e91e.jpg
and hot-spot in ECM ...
./uploads/201602/post_1744_1456213636_acd38849bc7d1dedd051872e394aec4b.jpg
RE: Flir
Thats what struck me about your camera, the high resolution. Very cool!
What a great tool! No way you would spot those problems otherwise.
Makes a temp gun look like a toy!
RE: Flir
All this talk of thermal imaging, I'm surprised nobodies mentioned cats new toy the S60 a mobile cell phone with the thermal camera built right in running on Android, it boasts some pretty cool features. Here's the like to read up on it.
http://www.cnet.com/products/cat-s60/
If it worked on goolge fi ID get it for bragging rights an the rugged tough build, cause I'm forever dropping my phone.
03-05-2016, (Subject: Flir )
RE: Flir
[/quote]and hot-spot in ECM ...[/quote]
Does a hot spot on the ECM indicate a problem? If so, what temp or above constitutes a hot spot with engine at normal operating temp?
RE: Flir
(03-05-2016 )texasmorrell Wrote:  Does a hot spot on the ECM indicate a problem? If so, what temp or above constitutes a hot spot with engine at normal operating temp?
That particular ECM was still working. It just was a little hotter than I see them get on the inside, indicting it was likely weakened at some point by a bad sensor or actuator
