| Chassis node per input fault |
| 03-05-2019, (Subject: Chassis node per input fault ) Post: #1 | |||
| Chassis node per input fault IsX 2013 Kenworth T660 I'm getting chassis node power input check faulty fuse regen light comes on every time I crank the truck says sit level high but it's not check filter seems to park regen for short periods then cuts off other than that truck runs fine anybody have any ideas sometimes I get a random injector one not responding also | |||
