Code 3138 engine exhaust gas recirculation outlet pressure |
03-20-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #1 | |||
Code 3138 engine exhaust gas recirculation outlet pressure Here we go again with more emmisions junk, replaced my bad egr and did successful forced regen. Then 4 miles down the road 3138 came up. I replaced both sensors double checked the wiring and connection, all good there but this darn code keeps coming back putting everything into derate. Anyone else had this issue yet ? | |||
03-20-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #2 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure FAULT CODE 3138 -- Engine Exhaust Gas Recirculation Outlet Pressure - Data Erratic, Intermittent, or Incorrect. your red cry-baby is trying to tell you that the EGR pressure is not changing with engine conditions. ... Possibly... * The egr valve is stuck * The EGR pressure sensor itself is reading ok, but is not changing with engine load (bad sensor or someone has attempted to bypass it with a resistor, etc). * corrosion in the wiring harness. * The EGR piping is blocked somewhere. * severe restriction in the EGR cooler. ============ To reset the fault after the problem has been fixed, it says to let engine idle for 5 minutes, then shut off for 1 minute, then turn key back on without cranking the truck and wait another 1 minute before performing a "clear all faults" in Insite. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
03-20-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #3 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure Followed that procedure and still about 4 Miles code popped back up, could a bad delta p cause this reading ? | |||
03-20-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #4 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure (03-20-2019 )Ironhead Wrote: Followed that procedure and still about 4 Miles code popped back up, could a bad delta p cause this reading ? possibly. Also check the circuit feeding the sensor for blockage. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
03-20-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #5 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure Well replaced the delta p as well, cleared the codes and popped back up after 8 miles this time. Still the same 3138 all the egr tubes look and sensors have been replaced, took all my lunch money ready to burn this thing to the ground | |||
03-20-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #6 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure Ok so idk what gremlins I chased away or what but swapped the 2 pressure switches cleared the codes and was able to drive 78 miles and still no check engine light or derate, I'll take it as long as itll let me | |||
03-21-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #7 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure Spoke too soon gremlin is back as a 2554 exhaust gas pressure 1 code, it idles fine, forced regen it surges and rolling down the road at 63 mph every once in a while when I let off the throttle it does a chug thing. | |||
03-21-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #8 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure (03-21-2019 )Ironhead Wrote: Spoke too soon gremlin is back as a 2554 exhaust gas pressure 1 code, it idles fine, forced regen it surges and rolling down the road at 63 mph every once in a while when I let off the throttle it does a chug thing. sounds like maybe one of the 2 sensors you have there that you swapped is bad?. Swapping sensors around should be done with caution as well. Many look the same style/color but may not be compatible. In the case of the EGR pressure sensor and the Exhaust gas pressure sensors,.. they may be the same part#'s on some enignes. Before assuming though, a person should always look on quickserv.com and ensure they have the right part#'s/are the same before swapping them around. User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
03-21-2019, (Subject: Code 3138 engine exhaust gas recirculation outlet pressure ) Post: #9 | |||
RE: Code 3138 engine exhaust gas recirculation outlet pressure I'll double check that, kw in Columbus Ohio is where I got them, they both are new and tech said they are the same, but it's a stealership lol | |||
