Signature 600 chuffing
07-31-2019, (Subject: Signature 600 chuffing )
Post: #28
RE: Signature 600 chuffing
if you bought it on ebay you need to contact the seller with PC ID for the codes.
 Thanks given by: Creek
Post: #29
Yes. I just stumbled across that info. Bought it on Amazon actually. US version. Thank you.
08-03-2019, (Subject: Signature 600 chuffing )
Post: #30
So I am setup with Insite now Doing a couple of tests. On the cylinder cutout test is the passing criteria the ability to maintain consistent RPM on a single cylinder? And what else should I be looking or listening for. What does the fuel percentage numbers mean? The cylinder performance test passed with all above 95% except 3 which hovered around 90. Does this indicate anything? Thanks
Post: #31
(08-03-2019 )Creek Wrote:  So I am setup with Insite now Doing a couple of tests. On the cylinder cutout test is the passing criteria the ability to maintain consistent RPM on a single cylinder? And what else should I be looking or listening for. What does the fuel percentage numbers mean? The cylinder performance test passed with all above 95% except 3 which hovered around 90. Does this indicate anything? Thanks
this may help...
Post: #32
Thank you!
Post: #33
So running on the individual cylinders, they would all keep the engine running. However, idle speed would drop from 730 to about 500 and then ramp, recover some rpms then drop again. It did this on all cylinders except #2, it didn't lose any rpms. The single cylinders sound really strong but the rpm drop has me curious. Weak injectors? I get 8+ mpg hauling light at 60mph. The lifetime engine load data said 14%. Don't sound like much of a load.
08-04-2019, (Subject: Signature 600 chuffing )
Post: #34
My apologies. After a more thorough gleaning of this forum I see that these questions have been asked and answered a jillion times. thanks
