| Check eng light |
| 04-17-2019, (Subject: Check eng light ) Post: #1 | |||
| Check eng light Isx 2350 check eng light code 4858 What's it for Thanks for any help | |||
| 04-17-2019, (Subject: Check eng light ) Post: #2 | |||
| RE: Check eng light my FIS says code 4858 is not found. what kind of truck? some hsitory? etc.? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
| 04-18-2019, (Subject: Check eng light ) Post: #3 | |||
| RE: Check eng light Rechecked with code reader my bad it's spn5848 Peterbuilt 2014 I do the check on dash & it comes up connect service tool If I cycle the key switch to off & on generally 6-8 times the light goes out for awhile but getting more frequent Gonna try & get insite set up just not good with computer but I know this needs to happen soon | |||
| 04-19-2019, (Subject: Check eng light ) Post: #4 | |||
| RE: Check eng light I found this... https://www.justanswer.com/medium-and-he...-code.html Here is what it says, I will only paste the first part, follow the link for the rest... Here is the Cummins full note on the fault so you can give to the shop and not have to go through the diagnostic fee. Fault Code 3936 SPN 5848 FMI 12 Aftertreatment 1 SCR Intermediate NH3 Sensor- Bad Intelligent Device or Component | |||
| 04-21-2019, (Subject: Check eng light ) Post: #5 | |||
RE: Check eng light (04-19-2019 )Waterloo Wrote: I found this... https://www.justanswer.com/medium-and-he...-code.html Thanks for the help Waterloo At least now I have a direction to go before it becomes a problem | |||
| 05-13-2019, (Subject: Check eng light ) Post: #6 | |||
| RE: Check eng light Replaced the NH3 probe & module everything fine for about 4 days then check light again, Clear it goes a bit then again more of the same Seems to be intermittent Ran it on insite did regen Everything checks out good Kinda baffled | |||
| 05-13-2019, (Subject: Check eng light ) Post: #7 | |||
| RE: Check eng light How about the SCR system filter? I hear they throw some wild codes if not changed regularly. How many miles on the truck? | |||
| 05-14-2019, (Subject: Check eng light ) Post: #8 | |||
| RE: Check eng light Not sure what scr filter is Truck has 291,000 miles 8,800. Eng hrs | |||
| 05-14-2019, (Subject: Check eng light ) Post: #9 | |||
| RE: Check eng light You have to put DEF in the truck correct? Or has it been deleted? The DEF is fed through the SCR system, there is a filter under there somewhere near the DEF tank, that needs to be serviced now and then, I would think at least once or twice a year. If not serviced strange codes pop up and can lead to further SCR system damage if I recall correctly. I have an older truck, no SCR system, just going by what I have read here and heard at Mr Hagg's shop and Rawze's house. If you have a delete, I am assuming you do not, and are getting this SCR code, I would say you have other, possibly more serious issues going on, and need to have the programming inspected. I wish I could be of more help, hopefully one of the guys with SCR experience will chime in. | |||
