Its a Volvo Problem
04-19-2019, (Subject: Its a Volvo Problem )
RE: Its a Volvo Problem
Switch your red and orange lines and report back. Red line is usually almost always emergency which where your orange line is at now, and according to meritor that part of the valve is the emergency portion.
 Thanks given by: snailexpress
04-20-2019, (Subject: Its a Volvo Problem )
I just replaced my pass through manifold. I didn’t see a line like that. I think that line is broke or disconnected. Trace that line down to where it comes out from maybe that will give a idea what it might go too
 Thanks given by: marek4792 , Waterloo
(04-20-2019 )Magard Wrote:  I just replaced my pass through manifold. I didn’t see a line like that. I think that line is broke or disconnected. Trace that line down to where it comes out from maybe that will give a idea what it might go too
lol if thats the issue im going to retire from working on trucks..... i'm going to go outside and check if its broken.
So nope those lines are supposed to be like that, I didn’t find any broken lines or leaking ones. I do have leaks coming from the air tanks lines but they aren’t heavy leaks, I’ve never had a issue like this before...
This is the new updated tractor protection valve, is the plumbing right?
My valve.
This is a 2012 Volvo vnl630. With isx. My colors are different locations then yours but I don’t know if color coordination is the same. I would try it though. Not much to hurt in trying.
04-21-2019, (Subject: Its a Volvo Problem )
Aren’t cell phone cameras awesome
 Thanks given by: Magard
(04-20-2019 )Evotrucker Wrote:  This is the new updated tractor protection valve, is the plumbing right?
All ports on the valve are marked. Volvo parts salesman doesn't know really much about parts they sell. Updated valve could have different ports layout. Green is service, red is emergency supply. Brown is control back to push valve on the dash. Black is hand trailer brake (Johnson bar)
Yellow line what is leaking air is air exhaust line. When you pull out red button out air pssssssss is from this line.
looks like you messed with ports connections and dash valve wants to pop out.
./uploads/201904/post_1794_1555866300_c70ef53d26b11ed0e6646ce057320277.png
