Egr water outlet tube
05-18-2016, (Subject: Egr water outlet tube )
Hi, I am having a slow leak coming from the top of the flex hose that is permanent attached to that outlet tube. I am wondering if I can cut that hose off and put on a new rubber hose with clamps instead of buying the whole tube? It is number 15 in the picture.
./uploads/201605/post_585_1463590552_c0c0368f44485dacb24f921221233633.png
RE: Egr water outlet tube
It depends on what shape the pipe is in. If it has rust on it at all i would change if not then just the part will be fine.
