Solid upside down triangle in dash
04-23-2019, (Subject: Solid upside down triangle in dash )
2014 international prostar Cummins isx. Upside down solid triangle popped up in dash. Can anyone help?
RE: Solid upside down triangle in dash
Could be low coolant, or any number of engine warning reasons....can you bring up tge codes by pressing the cruise on+resume at the same time?
(04-23-2019 )Nilao Wrote:  Could be low coolant, or any number of engine warning reasons....can you bring up tge codes by pressing the cruise on+resume at the same time?
I’ll have to try that tomorrow
Also look at display if it says ESC module could be hot exhaust or light next to it is out on dash
 Thanks given by: david24
