|  About code Mid 128 Pid 157 Fmi 1  |
|  04-24-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #1 | |||
| About code Mid 128 Pid 157 Fmi 1  Hi I have 06 Volvo with Cummins ISX CM870 my problem is truck runs on high rpm can’t lower rpm runs between 1300 and 1500 rpm sometimes over 1500rpm only 1 code is coming up only when I drive 1/2 mile this code will popped up Mid 128 Pid 157 Fmi 1  | |||
|  04-24-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #2 | |||
| RE: About code Mid 128 Pid 157 Fmi 1  sounds like you need to invest 200-300 on ebay for this  https://www.ebay.com/itm/INLINE-6-Data-L...D&LH_BIN=1 | |||
|  04-24-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #3 | |||
| RE: About code Mid 128 Pid 157 Fmi 1  if a metering actuator is leaky, they will rev up like that.  User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
|  04-24-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #4 | |||
| RE: About code Mid 128 Pid 157 Fmi 1  MID 128 Engine  PID 157 Injector Metering Rail Pressure FMI 1 Data Valid but below normal operational range https://www.thetruckersreport.com/trucki...es.243097/ User's Signature: The creator said " Help your self and I will help you; Protect your self and I will protect you " | |||
|  04-24-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #5 | |||
| RE: About code Mid 128 Pid 157 Fmi 1  I got insite but not with me at moment yes I already oredered metering actuator  | |||
|  04-24-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #6 | |||
| RE: About code Mid 128 Pid 157 Fmi 1 (04-24-2019 )Lonestar10 Wrote: sounds like you need to invest 200-300 on ebay for this I got Cummins insite but not with me at moment thank you anyway | |||
|  04-24-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #7 | |||
| RE: About code Mid 128 Pid 157 Fmi 1 | |||
|  04-26-2019, (Subject: About code Mid 128 Pid 157 Fmi 1 )  Post: #8 | |||
