| Sounds like a boost leak |
| 04-26-2019, (Subject: Sounds like a boost leak ) Post: #1 | |||
| Sounds like a boost leak My demandated 871 sounds like it has a boost leak but the noise is coming out the exhaust. I don't understand what could cause this. Any ideas would be helpful. Performance and fuel mileage don't seem to have changed any. | |||
| 04-26-2019, (Subject: Sounds like a boost leak ) Post: #2 | |||
| RE: Sounds like a boost leak Did you hollow everything out properly when you demandated it? There should be nothing but empty cans attached to your truck. Anything left inside them will cause soot build-up and exhaust restrictions. | |||
| 04-26-2019, (Subject: Sounds like a boost leak ) Post: #3 | |||
| RE: Sounds like a boost leak I left about 1 inch all the way around the outside everything else is gone | |||
