| N14 Select |
| 04-30-2019, (Subject: N14 Select ) Post: #1 | |||
| N14 Select Hi, I’m have a bit of trouble with my gravel truck. I have a 1994 kenworth with an N14 select. I had it inframed a couple years ago, but I didn’t do the injectors or turbo or fuel pump. It doesn’t get used a whole lot, but it has developed a miss on one cylinder. It runs and idles fine, but when your accelerating is when it starts missing. Just wondering if it might be an injector? I’ve changed the fuel filters but didn’t seem to help. Does insite work on N14? Thanks for any help | |||
| 04-30-2019, (Subject: N14 Select ) Post: #2 | |||
| RE: N14 Select Does the miss go away, when disconnecting the injector connector on drivers side of engine? If this is the case, you have discovered the problem. User's Signature: It's hard to win an argument with a smart person, but it's damn near impossible to win an argument with a stupid person | |||
| 05-01-2019, (Subject: N14 Select ) Post: #3 | |||
| RE: N14 Select 90% chance its a bad injector. This is very very common with the n14. | |||
| 05-01-2019, (Subject: N14 Select ) Post: #4 | |||
| RE: N14 Select Most failing celect injectors will stutter under acceleration/between gear changes. You need someone to cut them out while you drive. Once you think you've picked the one, cut out it's paired cylinder (1-6 / 2-5 / 3-4) and you will feel the "double miss" as the engine is roughly balanced on 4 cyls for a moment. | |||
| 05-01-2019, (Subject: N14 Select ) Post: #5 | |||
| RE: N14 Select It could be in the wiring harness as well User's Signature: The missing link | |||
| 05-01-2019, (Subject: N14 Select ) Post: #6 | |||
| RE: N14 Select Ok, i haven't tried disconnecting anything yet. I'll go try that this afternoon. I do have an adpter to fit the com port to plug into my laptop. I'm not sure if the injector cutout test works on the N14 or not, maybe too old. Is it best to change all 6 injectors, or just the one giving the trouble? | |||
| 05-01-2019, (Subject: N14 Select ) Post: #7 | |||
| RE: N14 Select Insite will work on them , just change the one User's Signature: The missing link | |||
