Troubleshooting help
05-13-2019, (Subject: Troubleshooting help )
I've got an 08 CM871 Serial#79252599 485/1650 W/@m*m^2 and it keeps throwing fault code:
0629 - Turbocharger 1 Compressor Intake Pressure - Data Valid But Below Normal Operating Range - Moderately Severe Level
It comes and goes at random it seems like. Before this last round of tinkering there were 226 counts.
I've also had 70 counts of 2288 Turbocharger 1 Speed - Data Valid But Above Normal Operating Range - Least Severe and 13 counts of 3348 Turbocharger 1 Compressor Intake Pressure - Data Valid but below normal operational range - Most Severe Level
So far I've changed ALL the engine and turbo sensors, new air filter, and tried swapping with another known good ecm. Any help/ideas would be greatly appreciated.
RE: Troubleshooting help
Has the CCV element been drilled out and both aftertreament can elements been "liberated"?
Are you leaking oil profusely?
Is your air filter clean?
(05-13-2019 )Chamberpains Wrote:  Is your air filter clean?
Yes just put a brand new one in.
(05-13-2019 )Moose Wrote:  Has the CCV element been drilled out and both aftertreament can elements been "liberated"?
Yes yes and no oil leaks.
Has it happened all of a sudden or ever since the ecm was reprogrammed? Sounds like the VG tables need adjusting.
05-14-2019, (Subject: Troubleshooting help )
(05-13-2019 )Signature620 Wrote:  Has it happened all of a sudden or ever since the ecm was reprogrammed? Sounds like the VG tables need adjusting.
It has be a growing problem, I want to say it started happening a couple weeks after it was reprogrammed, but honestly, it sat for that long before it was driven on a regular basis. I guess I could try a stock program and just ignore the other faults...
05-15-2019, (Subject: Troubleshooting help )
how much boost is it making?
the symptoms you describe sound like an intake or exhaust restriction. After-market CAC?, Does get better power and boost when you have the exhaust disconnected from behind the turbo?
 Thanks given by: Techmech
(05-15-2019 )Rawze Wrote:  how much boost is it making?
It'll make about 36-38lbs boost on average. The cac appears to be genuine Navistar but I can't say with 100% certainty. And there doesn't seem to be any noticable difference with the exhaust disconnected. I will say whoever did the dpf filter made a complete mess of things and I had to clean that situation up/out.
