Insite
06-01-2019, (Subject: Insite )
RE: Insite
I get the same message when using CT for too long, if I let the screensaver turn on, or the inline just says I'm done for now. Yup, gotta back out. DISCONNECT (it's the important part) from the data port and start over. I have a J1708 port on my intertrashional. So up or downloading is a minimum 45 minute task. Its always a guessing game of whether it will be 45 min or 4hrs with multiple tries and start overs.
 Thanks given by: hhow55
11-21-2020, (Subject: Insite )
RE: Insite
Does Insite work with the Nexiq usb link (authentic)??
User's Signature: Newbeee O/O
2021 KW T880 5ax. Dumper
X-15 565 @1850 Re-"Productive series"
Allison. 4500RDS
RE: Insite
Yep, that’s what I use.
 Thanks given by: rolling18
11-22-2020, (Subject: Insite )
RE: Insite
(11-21-2020 )hookliftpete Wrote:  Yep, that’s what I use.
What is the source for insite?
I thought it was a super expensive "subscription" based program?
thanks.
Allison. 4500RDS
RE: Insite
thanks.
That is correct if for some reason you want a legitimate version of the program. Software trading in the open is against the rules of the forum. Buy some crafty Googling will get you what you need.
