1999 4700 coolant recovery tank
07-14-2019, (Subject: 1999 4700 coolant recovery tank )
I am looking for a coolant recovery tank mine is steel having a hard time finding one any help would be grat
RE: 1999 4700 coolant recovery tank
I think they have been updated. Post the VIN and a picture if you can.
 Thanks given by: earnies2
metal tank? -- maybe something similar to this?...
https://youtu.be/3L1HEfQZ-0g
07-16-2019, (Subject: 1999 4700 coolant recovery tank )
(07-14-2019 )DVT873 Wrote:  I think they have been updated. Post the VIN and a picture if you can.
Here is the VIN
2HSCNAER6YC056967
It is a 2000 4700
It has a round metal recovery tank...thanks in advance
(07-14-2019 )Rawze Wrote:  metal tank? -- maybe something similar to this?...
I don't think its fixable its leaking in several spots it needs to be replaced.
07-18-2019, (Subject: 1999 4700 coolant recovery tank )
Here is the VIN
2HSCNAER6YC056967
It is a 2000 4700
[/quote]
Recheck the VIN. My guy says that comes back as a 2000 9400. Only need the last 8.
http://detroitradiatorcorp.com/catalog/d...onal/truck
They may have what you need
Does your tank look like this except it is metal? They did upgrade these to plastic somewhere in the mid 90's. The brackets changed. Hopefully you can adapt your brackets or find some in a yard. They are stupid money from the dealer. So is the tank. Good luck.
https://www.amazon.com/Dorman-603-5101-C...B007TJG47I
(07-18-2019 )DVT873 Wrote:  Does your tank look like this except it is metal? They did upgrade these to plastic somewhere in the mid 90's. The brackets changed. Hopefully you can adapt your brackets or find some in a yard. They are stupid money from the dealer. So is the tank. Good luck.
No mine is round ?
