1999 4700 coolant recovery tank
07-18-2019, (Subject: 1999 4700 coolant recovery tank )
RE: 1999 4700 coolant recovery tank
(07-18-2019 )DVT873 Wrote:  Here is the VIN
2HSCNAER6YC056967
It is a 2000 4700
It has a round metal recovery tank...thanks in advance
Recheck the VIN. My guy says that comes back as a 2000 9400. Only need the last 8.
[/quote]
Sorry it's a 9400...mybad
That round coolant tank can be had from almost any salvage yard. 9200's and 9400's for about 10 years used those tanks. Those trucks were very common fleet trucks for mid sized to large fleets across the country. Im sure you'll find one quite easily in good shape.
I will look I really wanted a new one
maybe this helps?
https://www.stockwiseauto.com/dorman-603...953f37790&
 Thanks given by: Chamberpains , earnies2
07-19-2019, (Subject: 1999 4700 coolant recovery tank )
(07-18-2019 )Nilao Wrote:  maybe this helps?
Yes sir that looks just like the original one thanks...
