Fuel in oil please help part 2 |
07-21-2019, (Subject: Fuel in oil please help part 2 ) Post: #1 | |||
Fuel in oil please help So I have a 2013 cascadia with an isx. I [/size]just did a complete rebuild. I got approx 10,000miles out of it then started noticing my oil level rising. Figured out it was fuel after a couple of days. My mechanic put die in and said three injectors were leaking so I had him change all six. I get my truck back yesterday drove 600 miles and checked oil I got about 2 gallons for fuel in there. Any ideas will be appreciated | |||
07-22-2019, (Subject: Fuel in oil please help part 2 ) Post: #2 | |||
RE: Fuel in oil please help Could be leaking past the plungers in the fuel pump - Assuming this is a common rail (cm2250/2350) engine. | |||
07-27-2019, (Subject: Fuel in oil please help part 2 ) Post: #3 | |||
Fuel in oil please help part 2 Fuel in oil after rebuild. So far did all injectors. Fuel pump. New head. And all new lines. Still leaking in oil. Any more ideas? | |||
07-27-2019, (Subject: Fuel in oil please help part 2 ) Post: #4 | |||
RE: Fuel in oil please help part 2 where did the head come from? Was is a new OEM head? -- a certified cummins reman? , or something a shop repaired?. Check the part# and date stamping on the intake side of the head near cyliner #6 ![]() ========================== NEXT: --- DOES IT PASS A RAIL LEAK TEST??? User's Signature: ->: What I post is just my own thoughts and Opinions! --- I AM Full Of S__T!. | |||
07-27-2019, (Subject: Fuel in oil please help part 2 ) Post: #5 | |||
RE: Fuel in oil please help part 2 | |||
07-27-2019, (Subject: Fuel in oil please help part 2 ) Post: #6 | |||
RE: Fuel in oil please help part 2 Run the engine with tracer dye in the fuel and shine a UV light around the overhead as it idles . | |||
07-30-2019, (Subject: Fuel in oil please help part 2 ) Post: #7 | |||
RE: Fuel in oil please help part 2 I just talked to my mechanic. He just did the die test again and said hes seeing all six of my brand new injectors leaking. | |||
07-30-2019, (Subject: Fuel in oil please help part 2 ) Post: #8 | |||
RE: Fuel in oil please help part 2 Were they Cummins remans or something off ebay? Where did they come from? | |||
07-30-2019, (Subject: Fuel in oil please help part 2 ) Post: #9 | |||
RE: Fuel in oil please help part 2 The head Is supposed to be brand new. It was bought from a shop not Cummins. Does have 1 year warranty. I talked to the mechanic he never did the computer test just put die in and seen it leaking at the injectors. He just did the die test again now hes saying all six of my new injectors are leaking. We found someone to bring the computer in the next couple of days so we will see how that goes. Are you thinking it's the head? Thank you for your time. | |||
